Release Notes
- Next release: v3.4b
- Power save mode (IDLE): timer 2,3,4,5... did not reacts properly in idle mode, making any peripheral using theses timer not working properly WHEN the POWER SAVE MODE were activated (in Master block).
- 30/12/2010: v3.4
- Input Capture : ICxMax value correspond to the max time defined including the margin (which is 10% by default)
- 24/12/2010: V3.3c
