Picooz
Revision as of 21:48, 16 March 2011 by LubinKerhuel (talk | contribs) (→‎Sky Cruiser (NIKKO))
Miniature flying helicopter Picooz from Silverlit
  • One Picooz
  • One Atlas
They are built by Silverlit
Picooz
Inside a Picooz, different part with their respective weight
Weight
  • EPP : 1.57g
  • Main propeller + main rotor + support : 4.55g
  • accumulator : 1.87g
  • Electronic board : 0.85g
  • tail propeller : 0.08g
  • tail motor : 0.63g
  • tail motor housing : 0.17g
  • tail main bar : 0.37g
  • tail paper : 0.02g
  • tail thin bar at the end : not measured but very small
  • Total (Original Picooz measurement) : 10.40g
main rotor force
Tail rotor force
Accumulator
Onboard electronic
Before and after disassembling. these two versions fly successfully
  • controlling the main rotor and the tail propeller.
  • demodulating the IR from the remote control
Atlas
Sky Cruiser (NIKKO)
Miniature flying helicopter Sky Cruiser NIKKO
  • Total weight: 23.97g
  • Red external cokpit weight: 2.76g
Accu: Full River 140mAh This helicopter does not have enough power to lift-up its weight except for the 20 first seconds. Then, the helicopter flight close to the ground thanks to the ground effect. Remote control is not an Infra Red one, but a real radio link (27Mhz). Removing the red cockpit allows normal flight, except that it goes slightly backward. The thin wire on the picture is the helicopter antenna (and not a broken wire that should be soldered to the tail rotor as it has been reported on some forum).
