Release Notes
- 19/12/2011: v3.7b
- 08/10/2011: v3.7
- 11/09/2011: v3.6c
- 07/09/2011: v3.6b
- 25/07/2011: v3.6
- Chip added : 256GP710A
- 15/05/2011: v3.5b
- 21/04/2011: v3.5
- 01/03/2011: v3.4c
- Examples updates
- 13/01/2011: v3.4b
- 30/12/2010: v3.4
- 24/12/2010: V3.3c
