DsPIC Block/Digital Input
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/Digital Input to DsPIC Block/Digital Input: Block is a special page, creates many issues)
Block Digital Input
The Digtal Input block reads the logical value of the selected microcontroller pin.
Digital Input Dialog
Port
  • Port used
Pin
  • Pin used, start at 0 and is defined in vector form allowing several Pin to be read at the same time.
  • -1 is inherited
