DsPIC Block/Ports Info
< DsPIC Block
Revision as of 18:30, 3 May 2015 by LubinKerhuel (talk | contribs) (LubinKerhuel moved page Block/Ports Info to DsPIC Block/Ports Info: Block is a special page, creates many issues)
Block Ports Info
This block only provide inforamtion. It does not affect the simulation nor the generated code.
It list all dsPIC/PIC Pins used and provide information about which peripheral are using theses pins. Opening the block only update its contents which is also printed in the workspace.
