Revision as of 10:27, 14 June 2008 by LubinKerhuel (talk | contribs)
Lets:
  • <Tex>\Theta= atan \left( \frac{a_z}{a_x} \right)</Tex>
  • <Tex>\Phi = atan \left( \frac{a_z}{a_y} \right)</Tex>
Log real data
Simulation based on real data
Remarks
Futur work
