Explorer 16 Board
Revision as of 13:42, 14 June 2008 by LubinKerhuel (talk | contribs)
  • One led (Port A7) :
Set UP
Simulink
PIC
Master block configuration
Open the Master block.
Set up PIC peripheral
Digital Input Configuration
Digital Output Configuration
ADC Configuration
UART
UART Peripheral Configuration
Functions
Blinking Leds
Filtering
The output value of the ADC block is also filtered with two different filters. One first order filter with a frequency cut off at 1Hz designed with the matlab command line >>c2d(tf([6],[1 6]),.005,'tustin') (need the Control System Toolbox) and One first order filter with a frequency cut off at 10Hz designed with the matlab command line >> c2d(tf([60],[1 60]),.005,'tustin')
html report with the C code generated can be generated. Go to Simulation ==> Configuration Parameters ==> select Real Time Workshop on the left column and check the option Generate HTML report on the right pannel. The model was compiled with Matlab 2007. dsPIC 33FJ256GP710 24JF128GA010 Matlab Report
Matlab Report Hex file to download to target
Logging and Plottng Datas
Pic side
Computer side
