Revision as of 00:41, 15 June 2008 by LubinKerhuel (talk | contribs)
Current release : 3.7e
Release date : 10 sep 2012
  • Mathworks components
    • Simulink
  • Microchip components
    • C30 compiler for PIC24, dsPIC30 and PIC33 family (tested with version v3.10b)
    • C32 compiler for PIC32 family (tested with version (v1.02)
  • Start Matlab
  • Uninstall the old blockset
  • install the new one
