The blockset Generates C code wit one click from a simulink model for a wide list of Microchip microcontroller. The geenrated C code is compiled on the fly to get the binary file ( .hex and .cof file) ready to be downloaded into the targeted microcontroller. The downloaded program behave similarly to the simulink model.
This fast prototyping tool for 16 bits PIC MCU :
Possible target are most of the dsPIC30f, dsPIC33, PIC24H and few PIC32. ( see detail on the download page) Supported Chip :
