DsPIC Block/Master
< DsPIC Block
Revision as of 23:45, 25 May 2008 by LubinKerhuel (talk | contribs) (New page: <Big>The Master block set important dsPIC options like PLL, Quartz used, and share theses parameters with others blocks from the blockset.</Big> [[Image:Block_Master.png|thumb|left|Master ...)
Master Block
Illustration not up to date !
Step Based on
PIC
59 Supported devices : 24fJ128GA006, 24fJ128GA008, 24fJ128GA010, 24fJ64GA006, 24fJ64GA008, 24fJ64GA010, 24fJ96GA006, 24fJ96GA008, 24fJ96GA010, 30f2010, 30f2011, 30f2012, 30f3010, 30f3011, 30f3012, 30f3013, 30f3014, 30f4011, 30f4012, 30f4013, 30f5011, 30f5013, 30f5015, 30f5016, 30f6010A, 30f6011, 30f6012, 30f6013, 30f6014, 30f6015, 32MX360F512L, 32MX460F512L, 33fJ128GP206, 33fJ128GP306, 33fJ128GP310, 33fJ128GP706, 33fJ128GP708, 33fJ128GP710, 33fJ128MC506, 33fJ128MC510, 33fJ128MC706, 33fJ128MC708, 33fJ128MC710, 33fJ256GP506, 33fJ256GP510, 33fJ256GP710, 33fJ256MC510, 33fJ256MC710, 33fJ64GP206, 33fJ64GP306, 33fJ64GP310, 33fJ64GP706, 33fJ64GP708, 33fJ64GP710, 33fJ64MC506, 33fJ64MC508, 33fJ64MC510, 33fJ64MC706, 33fJ64MC710
Instruction Cycle Frequency
Specify the Instruction Per Secondes (MIPS) executed not gven in million here. Configuratoin of UART baud, timers prescaler and the time step rely on this frequency information. When using a quartz, the instruction frequency is calculated using : IPS = (FreqQuartz / 4) * PLL factor (1 if no PLL used).
Config Timer
Busy Flag Port
Busy Flag Port
config Oscillator mode
config Born Out Reset
config Power Time
config MCLR
