Talk:Miniature Inertial Measurement Unit - IMU
Revision as of 18:22, 20 August 2008 by LubinKerhuel (talk | contribs) (New page: Old datas ---- -Old data [[Image:IMU_simu_RealData_Curves.png|frame|center|Top curves : The X (yellow) and Z (cyan) accelerometers raw data with the Y axis rate gyro (pink). The y scale ...)
Old datas
-Old data
