DsPIC Block/ADC Analog to Digital Converter
Type
Mode
- Continuous Sampling and get last channel value : In this mode, all selected channel are continuously scanned and converted at high speed. When the simulink block outputs are read, the last value converted from each channel is used. This method provide the minimum time lag between the end of conversions and the calculations using theses values.
- Continuous Sampling get output vector : In this mode, all channel selected are scanned and converted at low speed allowing to get exactly the number of sample defined in 1 time step. For example, you can get 6 samples from both channels AN0 and AN1. The samples of AN0 (resp AN1) will have a fixed sample rate. To avoid missalignment between end of time step and sampling rate, considere using ADC as timer refference in the master block. In this case, the time step is triggered by the end of the ADC conversions.
Voltage Reference
Output Format
Interrupt Priority
AN Channel to convert
Max Value
Simulink set this variable equal to the max value for the AN converter. For 10 bits, it is 1024 and for 12 bits it is 4096. This variable is evaluated in the matlab workspace. It allows to normalise the output of the ADC and to keep calculation correct while changing from 10 bits to 12 bits mode.
External Input Resistor
Temperature °C
Provides the following informations :
- Tsmp : Time to sample 1 channel
- T/Channel : Time of sample and convert 1 channel
- Tall : Conversion time for all samples
