- 1 The RC model airplane
- 2 Embedded System
- 3 Rate gyro and Accelerometers data in flight
- 4 Airplane dynamics identification
- 5 Angular rate control loop
- 6 The RC model airplane
- 7 Embedded System
- 8 Rate gyro and Accelerometers raw data in flight
- 9 Airplane dynamics identification
- 10 Embedded controller
Caracteristics :
- 1m25 wingspan
- 400g weight
- 2 actuated surfaces
Embedded System
Classical RC Material
- Two servo motor (HPX )
Calculator
Sensors
boite maxim DALLAS : 9.35g
total : 85.71g
Recording In Flight Data
Data Recorder
SST
Telemetry
