DsPIC Block/Output Compare HW
Outline
- Time Up and Period
- Time Down and Period
- Time Set and Reset
Up or Down or Periode = <tex>T_{set} * \frac{OCmax}{MaxChannel}</tex>
With
Output Channels
Channels Input Type
Periode as block input
Period Max
