Pic32-gcc v1.04 bugfix
Revision as of 15:31, 14 July 2009 by LubinKerhuel (talk | contribs) (Created page with 'Bug reported on the Microchip .h definition file. * In the file int.h localised in \MPLAB C32\pic32mx\include\peripheral\int.h, * Lines (411, 424, 437, 450, 463) replace '''…')
  • In the file int.h localised in \MPLAB C32\pic32mx\include\peripheral\int.h,
  • Lines (411, 424, 437, 450, 463) replace INTCONbits by INT0CONbits.
  • Line 705, replace
#define mOC1SetIntPriority(priority) (IPC1CLR = _IPC1_OC1IP_POSITION, IPC1SET = ((priority) << _IPC1_OC1IP_MASK))
by
#define mOC1SetIntPriority(priority) (IPC1CLR = _IPC1_OC1IP_MASK, IPC1SET = ((priority) << _IPC1_OC1IP_POSITION))
  • Line 746, replace
#define mOC4SetIntSubPriority(subPriority) (IPC4CLR = _IPC4_OC4IS_MASK, IPC4SET = ((subPriority) << v))
by
#define mOC4SetIntSubPriority(subPriority) (IPC4CLR = _IPC4_OC4IS_MASK, IPC4SET = ((subPriority) << _IPC4_OCIS_POSITION))
Thanks to Jiri Sehnal from Humusoft for identifying theses bugs.
