Revision as of 10:54, 25 April 2010 by LubinKerhuel (talk | contribs)
Remote Control Glider (1m25 wingspan) equipped with sensors (Gyrometers, Accelerometers) and calculators (dsPIC 30f4012).
The RC model airplane
Caracteristics :
  • 1m25 wingspan
  • 400g weight
  • 2 actuated surfaces
Embedded System
Plane during the construction. Differents elements placed inside the planed are showed
Classical RC Material
  • one 6 channel receiver (GWS 610)
  • Two servo motor (HPX )
  • 4 accumulator NiMh placed in the noise of the plane
  • A beeper is also added. The plane can thus emit a sound to provide different indications and after a crash, to help research.
Calculator
Sensors
Micro Electro-Mechanical Sensor (MEMS) are used to estimate the attitude of the plane. Theses sensors have many advantages : They are small, lightweight, low power consumption, robust from the mechanical point of view (i.e. crashproof) and some are precise (rate gyro).
  • rate gyro (ADIS 16080 from analog device)
  • Accelerometers (MMA7260) from freescale
From both the rate gyro and the accelerometers, it is possible to compute the attitude of the plane. For more details on the calculation details, see the page dedicated to the Inertial Measurement Unit (IMU). Weight : Servos GWS HPX : 19g (X2) DC DC converter MCP1252-33X50 - MCP1253-33X50 (3.3V) ==> 2.92g DC DC converter (5.0V) ==> 3.73g Beeper : 3.95g SST SST25VF016B 16 Mbit SPI Serial Flash ==> 3.95g Card dsPIC 30f4012 ==> 17.87g Recepteur RS610 ==> 7g Capteurs Inertiels (2 gyro + 1 accelero) ==> 8.29g
boite maxim DALLAS : 9.35g
total : 85.71g
Recording In Flight Data
  • place a data recorder in the plane (Solutions with SD cards)
  • transmit data to a base-station using a wireless transmission system (Telemetry)
Data Recorder
SST
Telemetry
Electronic schematic of the two free2move Bluetooth module. The left is the F2M03GXA-S03 (USB version). Connected through USB to a computer, it is used as a long range USB Bluetooth dongle able to communicate with the second Bluetooth module. The left schematic is the embedded module: F2M03GXA-S01 (UART version). It is connected to the dsPIC microcontroller through UART. When both modules are paired, a virtual COM port is created on the computer allowing transmit/receive data from the embedded system.
(top) Ground station Bluetooth module made of a free2move F2M03GXA-S03. It is linked to a PC using a standard USB cable. (Bottom) Embedded Bluetooth module (F2M03GXA-S01) component connected to the microcontroller.
WT11 from Bluegiga
ZigBee solution
Inflight data transmitted via Bluetooth. Three curves pannel are presented. The first pannel (big one) present datas recorded during a short flight lasting 46s. The launch time and crash time are marked by the two wide black vertical line. Datas between theses two lines are taken inflight. The first three curves show the three glider angular rate measured with the three rate gyro (ADIS16080). The three curves in the middle are the acceleration as measured by the accelerometer (MMA7260). The last two curves are the remote control stick position controlling the plane, measured at the receiver level. The two subpannel, in the bottom left and bottom right are a close-up of the Launch and Crash detail. All data are recorded at 1Khz and the detail level is very high. Launch tme and Crash time are detected automatically by a script.
Model : Two first order system describe respectively the pitch and roll dynamic of the plane.
Angular rate control loop
Add your comment
Lubin KERHUEL website welcomes all comments. If you do not want to be anonymous, register or log in. It is free.
