DsPIC Block/PWM Motor Output
Main Dialog Box Parameters
General Input Enable
Input Periode
Output Channel
Periode
With
ValMax Periode Calcule
Centered
Gives information :
Dead Time TAB
Dead Time A - B
Dead Time Info
Dead Time PWMx Active
Dead Time PWMx Inactive
